#1 2018-06-22 09:50
aldrik
Menu
Hello all
with Q4os bêta (3), with classic Menu, sort by categories, i don't have "config center" in menu.
Regards
aldrik
#2 2018-06-22 14:51
Re: Menu
Yes, this is true it has been omitted from the classic category structure, I would imagine that the devs can easily fix this but for the time being you can create a desktop link (or a .desktop file) and use this as the command. Or you can of course just put this command into the "Run Command" dialog box accessed from right clicking the desktop.
konqueror --profile "ctrl_panel" --icon "kcontrol" --caption "%c" settings:/
#3 2018-06-22 18:27
Re: Menu
Yes, this should be and will be fixed. You could run the control panel as posted above, or more easily:
$ kcontrol
You can also run it using right click on "My Computer" desktop icon -> Control panel
#4 2018-06-22 19:52
Re: Menu
$ kcontrol
There's always an easier way to do things than I see. smile
#5 2018-06-23 09:51
aldrik
Re: Menu
Thank you. I have a desktop icon. That's was a bug report smile
The bêta version is really good and stable !
have a good day smile
#6 2018-06-23 10:50
Re: Menu
Q4OS bug added here https://sourceforge.net/p/q4os/tickets/74/ . You are welcome to vote or comment on the bug, thanks for reporting.
#7 2018-06-23 12:44
aldrik
Re: Menu
Ok thank you Team, I'll note that for future !
regards
