#1 2017-06-03 14:46
Dcop error on boot (Scorpion) but system works ok
I have noticed about three times on my laptop when switching on I get this error dialog pop up which says...
error message wrote:
There was an error setting up inter-process communications for TDE. The message returned by the system was:
Could not read network connection list.
/home/dai/.DCOPserver_scorpionmain__0
Please check that the "dcopserver" program is running!
The system seems to be running fine and I have not noticed anything strange happening, and my network connection (wifi) is established by the end of the startup procedure.
This is not happening every time I start the machine, but it has happened three times in the last four (or five?) days. Any idea what could be causing this? like I say it doesn't seem to be affecting anything other than displaying the error before desktop starts to load.
#2 2017-06-03 15:16
Re: Dcop error on boot (Scorpion) but system works ok
We will check it and post back as soon as possible.
#3 2017-06-03 15:22
Thanks guys, it doesn't appear to be affecting anything so could be like a false positive report or something.
#4 2017-06-03 16:09
Havent experienced that Dai but Im also running Scorpion on a desktop with ethernet connection.
#5 2017-06-03 16:25
Yea, a strange one as it seems to be all working after desktop appears but sometimes shows the error...
#6 2017-06-03 17:45
We are not able to reproduce so far. You could try to cleanup the TDE cache, just do login to terminal console, ctrl+alt+f1, make sure you are not logged TDE in. Remove all folders 'kdecache-*' in '/var/tmp/' directory and reboot. Please, post a result back.
#7 2017-06-03 20:44
I will do this now (when I log-out) although a quick look in /var/tmp shows only tdecache-* so should I assume they are the ones to remove?
EDIT:
I removed them as per your instructions, and rebooted and everything seems normal although I have started/shutdown the laptop about 4 times today and only had the error message happen on one occasion, also I forgot to mention (in case it is pertinent) I am using the auto-login feature too.
I will report here if the message comes back.
#8 2017-06-04 16:35
After you mentioned auto-login I played around with my test setup, but so far havent been able to cause the issue.
#9 2017-06-04 17:01
I haven't had it happen again yet and I've started and shutdown this laptop three time so far today. Let's hope it was just a glitch that doesn't return smile
#10 2017-06-04 18:48
Im around 30 times on three different installs.
#11 2017-06-05 11:13
Ok I got the error message again, this time I had the power adapter plugged in which I don't usually do. This is the only thing I have done differently and this is the third boot up today and the previous times no error message appeared. I will reboot the laptop a couple of times testing if power adaptor makes a difference all the time and post back with results.
EDIT:
I rebooted with power supply still attached and no error message, then removed power supply and rebooted without error message, I then powered off the machine reconnected power supply and restarted it after a few minutes and no error message... So conclusion is that may have been coincidental that power supply was attached when it last happened...
#12 2017-06-05 15:20
Ive tried to simulate what you did with my laptops but so far nothing.
#13 2017-06-05 15:32
Yes I can't reproduce the error so it could be something system specific... I might try a fresh installation when I have time. smile
#14 2017-06-05 15:58
Thats what I was thinking as it could be specific to your hardware.
#15 2018-02-28 06:04
JimW
Ok, to revive an old issue!
I was running Audacity with an 8 hour audio file. Then I tried to load a 5 hour file into another copy of Audacity. Everything hung up. No display refreshes. So I did a shutdown and reboot. But, I get the same DCOP server message at boot up and cannot startx unless I do so as root. (which I currently am running under) I have tried cleaning /tmp removing all the .DCOP files and the .ICEauthority with no luck. Getting late tonight and I got a busy day tomorrow so it may be day after tomorrow (Thursday) before I get back, or I may work on it some tomorrow evening.
When I copied my FireFox files to root I did get a popup that I was running out of space. Possibly I have just exceeded what disk space I have, so I may try cleaning some non-essential files and see what happens.
#16 2018-02-28 09:38
I still have the occasional error message when I boot up, but everything still seems to be working and nothing has stopped my desktop from showing and functioning as expected, I would suspect that hdd space could be the culprit in your case and also I would check the amount of swap space available too just in case that could be a problem.
After I get the error message I don't change anything, sometimes I might reboot just to see if it comes back (it hasn't happened after reboot as yet) but as I have had no detrimental effects I put it down to "one of those things" smile
#17 2018-02-28 22:09
JimW
Ok, I've removed over 40 Gb of data and it still gives the same error. After starting with sudo startx it comes up and says I still only have 3% free space! That was what it said before I moved the 40 Gb to USB thumb drives!
I have looked for files that Audacity may have left floating but can't find anything, even in .Audacity. Is there something I can do that would find those huge files and delete them? Since I was running 2 copies of Audacity when this happened I feel that there must be something that it caused that I need to get rid of. I have cleared /tmp so I don't think there is anything there. Possibly swap space? Any thoughts on what to do (other than never do that again!)?
Ok, back after trying a couple more things.
In /usr/tmp I found two files labeled "audacity-jim####" with the # being a bunch of numbers. I deleted those and shutdown (not restart).
Still cannot log in as user. When the login windows comes up and I enter user/password, it closes and opens a terminal window. Typing startx I get-
"Only console users are allowed to run x server"
So, I have to still use the sudo startx.
#18 2018-02-28 23:11
@JimW
You could try to cleanup the TDE cache, just do login to terminal console, ctrl+alt+f1, make sure you are not logged TDE in. Remove all folders 'tdecache-*' in '/var/tmp/' directory and 'tde*' in '/tmp'. Next remove directories 'cache-*' .. 'socket-*' .. 'tmp-*' in '$HOME/.trinity/' and reboot. You should also check and set ownership of all files in your home folder:
$ cd /home
$ sudo chown -R your_username:your_groupname your_home_folder
#19 2018-02-28 23:20
@JimW
Also you could run df and see if any mounts are low on space, it might give you a clue as to which part of the system is low. After running the previous instructions from the @q4osteam of course smile
#20 2018-02-28 23:51
JimW
Thanks Q4OSteam - it looks like the removal of the 'tdecache-jim' folder cleared the problem up. Able to log on normally now - sure hated running as root!
@Dai - thanks, I'll give it a check!
jim@arcadia:~/Desktop$ df
Filesystem     1K-blocks      Used Available Use% Mounted on
udev             1961592         0   1961592   0% /dev
tmpfs             394776     10720    384056   3% /run
/dev/sda2       28705700  13148324  14076160  49% /
tmpfs            1973860     10072   1963788   1% /dev/shm
tmpfs               5120         4      5116   1% /run/lock
tmpfs            1973860         0   1973860   0% /sys/fs/cgroup
/dev/sda3      927571136 256402068 623979872  30% /home
tmpfs             394772        12    394760   1% /run/user/1000
