#1 2017-12-11 16:36
ibenzawla
WiFi not Reconnecting Automatically after Restart
New user here. Love Q4OS so far. I have been checking the forum for a way to solve my wifi connection issue but unable to get a solution. I am able to connect to wifi but it doesn't automatically reconnect after the computer restarts. I have to manually reconnect after every restart.
#2 2017-12-11 18:13
Re: WiFi not Reconnecting Automatically after Restart
You only need to set autoconnect option. Just click on the wireless manager applet in the system tray > Edit connections > select a wifi connection to configure > Edit > click Next, step by thru the guide, don't forget to check 'Autoconnect' option > click Save.
#3 2017-12-12 05:07
ibenzawla
Thanks a million! Followed up your instructions and everything is working fine now. Amazing OS. Thanks again.
