#1 2025-07-25 16:11
Tomi
connecting internal hdd
My q4os system is on an ssd and I like it. But the laptop also has an internal hdd and the system doesn't see it. I would like to be able to write to it and delete files. The machine is an HP probook 440
#2 2025-07-25 18:41
Re: connecting internal hdd
Welcome to the forum smile
Run in terminal:
$ lsblk
$ sudo blkid
and post the output.
#3 2025-07-26 09:57
Tomi
Welcome!
Thanks for the answer, unfortunately it didn't help. I'm not an expert, I just copied the command you gave me.
It said this: bash: $: command not found
This is what it looks like in Hungarian:
$ sudo blkid
bash: $: parancs nem található
tomi@tomi-hpprobook440g6:~$
Sorry, but isn't there another command option?
#4 2025-07-26 10:09
run without the "$"..
lsblk
sudo blkid
coding & robotics enthusiast | Q4OS 6.4 TDE/XFCE + Win10 1903 on ASUS-E202SA (N3060 | 2GB RAM | 500GB HDD)
#5 2025-07-26 10:23
Tomi
Sikerült! Köszönöm midenkinek!
#6 2025-07-26 10:24
Tomi
It worked! Thank you everyone!
