#1 2016-10-02 19:41
ghostdawg
One reason I do not use KDE as much
I'm not knocking it but this is one of the reasons I do not like using KDE, too many dependencies, and it installs too many programs by default. Yes, I know large hard drives are cheap but still, I prefer a lean OS.  I know most of them are small in size. All this just to add kgpg?
$ sudo apt-get install kgpg
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  akonadi-backend-mysql akonadi-server docbook-xsl kate-data katepart
  kde-runtime kde-runtime-data kdelibs-bin kdelibs5-data kdelibs5-plugins
  kdepim-runtime kdepimlibs-kio-plugins kdoctools libakonadi-calendar4
  libakonadi-contact4 libakonadi-kabc4 libakonadi-kcal4 libakonadi-kde4
  libakonadi-kmime4 libakonadi-notes4 libakonadiprotocolinternals1
  libattica0.4 libboost-program-options1.55.0 libboost-thread1.55.0
  libdbusmenu-qt2 libdlrestrictions1 libdmtx0a libfam0 libgpgme++2 libiodbc2
  libkabc4 libkactivities-bin libkactivities-models1 libkactivities6
  libkalarmcal2 libkatepartinterfaces4 libkcal4 libkcalcore4 libkcalutils4
  libkcmutils4 libkde3support4 libkdeclarative5 libkdecore5 libkdesu5
  libkdeui5 libkdewebkit5 libkdnssd4 libkemoticons4 libkfile4 libkgapi2-2
  libkholidays4 libkhtml5 libkimap4 libkio5 libkjsapi4 libkjsembed4 libkldap4
  libkmbox4 libkmediaplayer4 libkmime4 libknewstuff3-4 libknotifyconfig4
  libkntlm4 libkolab0 libkolabxml1 libkparts4 libkpimidentities4
  libkpimtextedit4 libkpimutils4 libkpty4 libkresources4 libkrosscore4
  libktexteditor4 libkxmlrpcclient4 libmailtransport4 libmicroblog4
  libnepomuk4 libnepomukcore4 libnepomukquery4a libnepomukutils4
  libntrack-qt4-1 libntrack0 libphonon4 libplasma3 libpolkit-qt-1-1 libprison0
  libpulse-mainloop-glib0 libqca2 libqjson0 libqrencode3 libqt4-qt3support
  libsolid4 libsoprano4 libssh-gcrypt-4 libstreamanalyzer0 libstreams0
  libthreadweaver4 libupower-glib3 libutempter0 libxerces-c3.1 libxml2-utils
  mysql-server-core-5.5 nepomuk-core-data ntrack-module-libnl-0
  oxygen-icon-theme phonon phonon-backend-vlc plasma-scriptengine-javascript
  soprano-daemon upower
Suggested packages:
  akonadi-backend-postgresql akonadi-backend-sqlite dbtoepub
  docbook-xsl-doc-html docbook-xsl-doc-pdf docbook-xsl-doc-text
  docbook-xsl-doc docbook-xsl-saxon fop libsaxon-java libxalan2-java
  libxslthl-java xalan djvulibre-bin finger icoutils libcanberra-pulse
  sound-theme-freedesktop fam iodbc hspell libqca2-plugin-cyrus-sasl
  libqca2-plugin-gnupg libqca2-plugin-ossl media-player-info
  phonon-backend-gstreamer phonon-backend-mplayer virtuoso-minimal
  kdepim-runtime kdepimlibs-kio-plugins kdoctools kgpg libakonadi-calendar4
0 upgraded, 111 newly installed, 0 to remove and 0 not upgraded.
Need to get 76.7 MB of archives.
After this operation, 218 MB of additional disk space will be used.
Do you want to continue? [Y/n] n
Abort.
$ sudo apt-get install --no-install-recommends kgpg
  kdelibs5-plugins kdepim-runtime kdepimlibs-kio-plugins kdoctools
  libakonadi-calendar4 libakonadi-contact4 libakonadi-kabc4
  libakonadi-kcal4 libakonadi-kde4 libakonadi-kmime4 libakonadi-notes4
  libakonadiprotocolinternals1 libattica0.4
  libboost-program-options1.55.0 libboost-thread1.55.0 libdbusmenu-qt2
  libdlrestrictions1 libdmtx0a libfam0 libgpgme++2 libiodbc2 libkabc4
  libkactivities6 libkalarmcal2 libkatepartinterfaces4 libkcal4
  libkcalcore4 libkcalutils4 libkcmutils4 libkde3support4
  libkdeclarative5 libkdecore5 libkdesu5 libkdeui5 libkdewebkit5
  libkdnssd4 libkemoticons4 libkfile4 libkgapi2-2 libkholidays4
  libknotifyconfig4 libkntlm4 libkolab0 libkolabxml1 libkparts4
  libkpimidentities4 libkpimtextedit4 libkpimutils4 libkpty4
  libkresources4 libkrosscore4 libktexteditor4 libkxmlrpcclient4
  libmailtransport4 libmicroblog4 libnepomuk4 libnepomukquery4a
  libnepomukutils4 libntrack-qt4-1 libntrack0 libphonon4 libplasma3
  libpolkit-qt-1-1 libprison0 libpulse-mainloop-glib0 libqca2
  libqjson0 libqrencode3 libqt4-qt3support libsolid4 libsoprano4
  libssh-gcrypt-4 libstreamanalyzer0 libstreams0 libthreadweaver4
  libutempter0 libxerces-c3.1 libxml2-utils mysql-server-core-5.5
  ntrack-module-libnl-0 oxygen-icon-theme phonon phonon-backend-vlc
  plasma-scriptengine-javascript soprano-daemon
Suggested packages:
Recommended packages:
  libkactivities-bin upower
  kgpg libakonadi-calendar4 libakonadi-contact4 libakonadi-kabc4
0 upgraded, 105 newly installed, 0 to remove and 0 not upgraded.
Need to get 76.1 MB of archives.
After this operation, 215 MB of additional disk space will be used.
Abort.
Dell Optiplex 760 - Quad Core | 4gb | 250gb | Mageia 5, Salix 14.2, Q4OS
Lenovo Thinkpad T420 | 4gb | 120gb | Mageia 5, Debian Testing
#2 2016-10-02 19:43
Re: One reason I do not use KDE as much
Try kgpg-trinity
dai@q4os-desktop:~$ sudo apt-get -s install kgpg-trinity
  kgpg-trinity
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Inst kgpg-trinity (4:14.0.3-0debian8.0.0+0 Q4OS TDE repository:8.0/qtde-jessie-st [amd64])
Conf kgpg-trinity (4:14.0.3-0debian8.0.0+0 Q4OS TDE repository:8.0/qtde-jessie-st [amd64])
#3 2016-10-02 19:49
ghostdawg
Thanks, Dai_trying. I guess adding -trinity at the end makes a difference. I need to get used to how Trinity works.
#4 2016-10-02 19:58
You're welcome, you have to remember it's Trinity desktop not KDE, even though it is obviously based on KDE it's not quite the same. smile
#5 2016-10-11 16:40
orion
Hi Dai,  can you give me the reference page where i can see the dual boot installation win/ q4os? ( for make partitions and installing)  thanks!
#6 2016-10-11 16:44
The main site is dsbnet.tk and you can select from either drop down or navigation menu for partitioning or installation etc. smile
