#1 2019-03-18 03:34
ben706
Update old version
Greetings,
I am running q4os version 1.8.8 on an old hp laptop.  I haven't run this machine in awhile and when I try to get updates via the update manager I get an error code 100 message and the update stops.  When I try to update via the terminal I get the following message:
An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://repository.spotify.com stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY A87FF9DF48BF1C90
What are my options to upgrade/update the OS on this computer?
Thanks!!!!!
#2 2019-03-18 08:19
Re: Update old version
You need to update Q4OS keyring, run in terminal:
$ wget -nv -O- http://q4os.org/q4repo/q4a-q4os.gpg.pub | sudo apt-key add -
$ sudo apt update
$ sudo apt dist-upgrade
#3 2019-03-18 14:34
ben706
After running the first line to add the key I get:
2019-03-18 08:26:43 URL:http://q4os.org/q4repo/q4a-q4os.gpg.pub [1666/1666] -> "-" [1]
OK
Then after running the update command I get:
338 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://repository.spotify.com stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY A87FF9DF48BF1C90
W: Failed to fetch http://repository.spotify.com/dists/stable/InRelease
W: Some index files failed to download. They have been ignored, or old ones used instead.
sudo
Then after the upgrade command I get this:
Err http://repository.spotify.com/ stable/non-free spotify-client amd64 1:1.0.77.338.g758ebd78-41
  404  Not Found [IP: 13.249.94.17 80]
E: Failed to fetch http://repository.spotify.com/pool/non- … _amd64.deb  404  Not Found [IP: 13.249.94.17 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Any ideas?
Thanks!
#4 2019-03-19 11:46
Well, you also need to update Spotify keyring:
$ sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 931FF8E79F0876134EDDBDCCA87FF9DF48BF1C90
Or remove the Spotify repository from system. Edit Spotify related file in /etc/apt/sources.list.d/ directory and comment out the "deb ..." line.
Please see https://www.spotify.com/cz/download/linux/
#5 2019-03-20 03:39
ben706
Thanks for your help.  I was able to remove some leftover crap from spotify that must have been attached to wine....and bla bla bla...but your help led me there.  I've always thought the support for this OS was impressive.  Thanks!!!
